Originally Posted by benjy
the fitting itself is the issue!! the line going into it has a raised area + a clip that fits in a slot in the fitting, the line has movement once installed + ONLY the small O-ring seals it!! i have seen where some went to quality AN fittings but a costly deal for a sloppy GM part thats prolly made in CHINA!!!
You're right there's a slight ridge in the line, that's how the clip holds it in, but I doubt that's going to make a good seal with a hose. I once tried clamping two ends of a power steering hose together using a barbed metal fitting, it leaked no matter how much I tightened the clamps.
That small o-ring does work though, mine worked for 17 years without leaking. Also, mine didn't have movement in the fitting. The new ones that came with the new radiator (not GM, yeah made in China, probably) also don't leak (so far) and no play.
