LC + Auto RX
Houston, TX
Hey Guys,
Is it ok to you use Auto RX with LC? I plan on adding 3oz of Auto-RX on every oil changed for maintenance, and was wondering if there will be any negatives effects of adding in LC?
Tuan
Quote:
Do not use them together, they are competing
chemistries and will cancel each other out.
actually if you run a search you will find that Terry Dyson is actually mixxing thse 2 together...don't know the ratios ..but he says they do work together...the owner of Arx would not approve..nor perhaps lube control...
Wait for the first post of an Auto-Rx Application using new mileage parameters. The performance and mileage and cost to achieve will be oustanding. There will be no reason to use anything else.
Quote:
You can use the LC if you want, Autorx will just clean it out.
In my experience, LC20 may have spectacular anti-oxidant qualities, but there's no comparison in actual cleaning.
I am waiting for first post where cleaning went on for 2500 miles and rinse cycle for 3000 miles.
I wonder how important anti-oxidant additive will be? after this Auto-Rx Application.
It will still play a vital role, I feel. It will neutralize the bad acids that cause oxidation in the oil. They work to retain the TBN levels. Does it clean, no idea, but it will help.
