Is Champion COS3593a safe for Kia/Hyundai?
WA
The reason for question is that Champion recommends it for Kia/Hyundai as well as bunch of other Asian vehicles. Seems like Fram was doing the same with their PH3593a (same code), but then they've come up with 9688 line specifically for Kia/Hyundai (something related to spikes in oil pressure)
North of you Idaho
I thought the only real difference between the 9688/7317/3593A was size, 7317 was a bit smaller in diameter and little longer and only needed for some Honda's after about 2012, but they started spec'ing them in 2002 or 03. My Subaru takes 9688's but will take a 3593A also.
WA
Seems like Fram specifies 3593A for your Tribeca, 9688 will fit for sure but I saw it numerous times here on bitog that 9688 was designed specifically to deal with oil pressure issues of kia/hyundai I've got like 10 champ cos3593a and really not sure now if I should use them
Va
I was actually wondering the same thing. They is another manufacturer that groups the Hyundai part numbers with others like Honda. I think it was Purolator or Bosch? I kinda like that Fram has a unique part number for Hyundai and probably built to handle the oil pressure spikes. I also bought 3 of the COS filters off Rockauto and have been reluctant to use them on my Hyundai.
Athens, GA
Wix Specs their 51334 filter for the 2017 Kia Sportage which specs the same as the 3593A filters. 20x1.5mm Thread with an 8-11psi bypass. They also cross reference the PH9688 to the 51334 line of filters. I'd say it looks like you'd be ok using them.
Waco, TX
I also bought a bunch of COS3593A from RockAuto for my 2013 Kia Optima. Texas doesn't get crazy cold, so I am not expecting any excessive oil pressure issues. If one of them DOES fail, everyone here will know about it! LOL grin2
Texas Hill Country
The issue is pressure spikes. If you look at the OEM Hyundai filter it is built like a race car filter, and is heavy as a brick. If champion engineered the filter for this application they probably meet the pressure rating, so I wouldn't worry about it. I haven't messed with anything but the Hyundai filters because the dealer does a 5w30 blend oil change with new filter for $24.99, so I haven't bothered. Also I still have warranty on my engine so its "nice" to have oil changes on record at the dealer.
