I wanna run a constant, 30amp, circuit, in my Ford Ranger truck - wired to a relay, which will turn the circuit off when my truck is off.
I ordered 10 gauge wire from amazon, and it was supposed to be top of the line copper wire, but it turned out that it has an aluminum core (strand).
I wound up using a bit of the wire for a different project, so I can't return the roll. Is aluminum wire okay? I remember there being overheating in home electrical wiring, hence my distrust of aluminum. Everything else about the wire meets spec; would it be okay to use aluminum core wire on my auto project?
Thank you
Thank you
