I have an 02 Sienna. I got it in 2012 with 136k on it and now has 189k. I currently use about a quart of oil every 3000 miles.
Ever since I got it I've been using Castrol high mileage 10w30 in it. Why I chose the high mileage version is probably obvious, but I chose the 10-30 because I live in Orange County, California. For those that don't know, that's an area of the country that even in "cold" winter months in the middle of the night if you get into the 30s (36F = 2.22C) it's pretty rare and actual freezing is even more rare.
The chart in my owner's manual for the 10w30 says it's supposed to work just fine at above 0F/-18C with the range arrow going above 100F/38C.
So I figured if the upper range for both the 5-30 and the 10-30 is that and since we hardly ever dropped belong below 40F/4C, why not just use the grade that's a little closer to the base stock and go with the 10-30.
Plus, even though in the manual it says the 5-30 is the preferred grade. I figured the 10-30 was just as good as... and they put the 5-30 in there figuring a good many of the people that bought the car would be in very cold climates much of the time and no use switching back and forth between grades.
But then I was researching it some recently and I saw that some sites were saying 10-30 protects your engine up to an ambient temperature of 84F/29C degrees whereas 5-30 goes up to 96F/35C (okay. That's enough reference. I'm just sticking to Fahrenheit from here on). Both those numbers seem really low for an oil to protect a car in the summer months most anywhere in the US.
So I don't understand what they are talking about when they talk about the different ambient temperatures of the two types of multi-grade oil. I thought all oil that was marked as 30 grade on the high-end would protect the same.
So, have I really been doing my car a disservice all this time by using the 10-30, considering the temperatures I operate in?
Is there really THAT much of a delay of the oil getting up and into the engine to lubricate it from those initial "cold" starts.
Have I been killing my gas mileage at all by using a slightly thicker grade base oil?
