Originally Posted by CR94
Originally Posted by hallstevenson
... At a minimum, they'd position the seats in all vehicles to maintain the same distance across them. That won't necessarily mean the seat is in the middle of its adjustment or offset a fixed amount forward or backward either.
Probably at a position appropriate to the leg length of the standard dummy used in the test. That means a shorter dummy (or human!) would be at a big disadvantage in this sort of crash when the dash gets pushed rearward.
So that all means that in this particular test that particular dummy at 35 mph fared the way it did in the four trucks. Change a data point and all bets are off: 34 MPH , 40 MPH, 5'2" driver, slick roads, worn tires, a heavier or lighter vehicle in the real life off set crash.
This results of this test happened one time to each of these vehicles at a set rate of speed, in a lab against a similar weight barrier with an average sized dummy.
While this data has some value it's all self serving propaganda for insurance industry government lobbying.
You will never replicate this identical accident/crash in the real world in a million years. Stop dropping your jaws in shock everyone.
Your results will definitely vary inn the real world with a vastly different weight and size and rate of speed mix.
