Originally Posted by KrisZ
With direct injection fuel can be injected at any point during the cycle. All manufacturers have different fuel injection timings and lengths, but one thing is common, all of them do not use a single fuel injection time anymore.
So with multiple injection and variable exhaust and intake valve timing, all sorts of things are possible there weren't before.
However I don't think any if that can be used to somehow direct the fuel in order to clean the intake valves.
Well technically it's only got 2 strokes to be injected. It's either during stroke 1 or stroke 2. But I don't see during what stroke would opening both the exhaust and intake valves simultaneously occur?.. just so fuel could swim upstream to wash a valve??
There's positive cylinder pressure during strokes 2 and 3 but you wouldn't open the exhaust valve then otherwise you get no "boom". Stoke 1 is a vacuum.. that leaves stroke 4..but the problem with stroke 4 is there's no fuel left to clean anything
