HYUNDAI ; Manual tranny w/o a clutch pedal
USA
This has been tried a few times over the years: Porsche/VW Sport-o-matic, Saab Sensonic, and Ferrari tried it in the early 90s. None were reliable.
pa
if memory serves ...I think VW had something like that way back when...I could be wrong
Cincinnati, OH, USA
You're not wrong-some of the later air cooled VW Beetles had it, called Auto Stick. Combined the worst of an automatic (wacky vacuum activated clutch, power robbing non-lockuptorque converter) and a manual (having to shift gears). Somehow it sensed your hand on the shifter to allow you to shift-I personally never had one, but a high school friend did, it made his 1600 as slow as my conventional manual 1200 was!
British Columbia, Canada
I think Chrysler was trying something like this with the 1953 model year. The manual for my dad's '53 Plymouth talked about some models with a fluid drive ahead of the transmission. He had the regular manual transmission though. And I remember reading about something similar in hot rod magazines in the mid '60s, that is taking out the clutch and putting a torque converter in front of a manual transmission. I like using a clutch and a manual transmission. I consider it a life skill. My daughter has only ever owned cars with manual transmissions. And my wife double clutches out of habit.
St. Charles County, Missouri
Originally Posted by WhyMe
i don't see this much different from a DCT. put in gear and add gas and it engages . then row the gears . stuff is done in micoseconds .
Yeah, wouldn't manually shifting a DCT give you the same thing? So this is a DCT without the smarts?
Ontario, Canada
There were cars in the 1950s that had manual tranny and no clutch Citroen is the 1st to come to mind. Nothing new it was there before the auto tranny in Europe.
ZFW
I'll be honest, I have no idea how this will work. Especially when you really get to rowing through the gears- if you're anything like me, I don't let go of the stick and the adrenaline keeps my grip tight. I understand it will disengage the clutch after you shift, but I wonder if it would know when to reengage the clutch. Either way, I'm intrigued. If it works and is reliable, I'd buy it.
HI
The India market will be the first to get the transmission so there is some info on how it works: https://www.hyundai.com/in/en/hyundai-story/media-center/india-news.html#itemView
Quote
Hyundai's iMT technology features a Transmission Gear Shift (TGS) Lever with Intention Sensor, Hydraulic Actuator and Transmission Control Unit (TCU). The system has been designed to offer a seamless drive experience by incorporating a cohesive logic between the various components on manual transmissions: 1.Transmission Control Unit receives signal from TGS Lever Intention Sensor, indicating drivers desire to change gears. 2.TCU sends signal to engage Hydraulic Actuator forming Hydraulic Pressure. 3.Hydraulic Pressure is then sent to Concentric Slave Cylinder (CSC) through Clutch Tube. 4.Concentric Slave Cylinder uses this pressure to control the clutch and pressure plate, thereby engaging and disengaging the clutch. 5.Driver is able to seamlessly shift gears without the need to mechanically operate clutch pedal.
Winnipeg
Originally Posted by ecotourist
I think Chrysler was trying something like this with the 1953 model year. The manual for my dad's '53 Plymouth talked about some models with a fluid drive ahead of the transmission. He had the regular manual transmission.
Not quite. The fluid-drive semi-automatic required a clutch pedal. https://youtu.be/z4L0NURxm64
JHZR2
Staff member
New Jersey
+1, unless its much less complex because its a SCT (single clutch transmission). I would think that if companies can make DCTs, and ABS, and all forms of other precision hydraulic and electronic machines, thata clutch actuation thats faster and better than a human foot would be very possible. Give up some control, yes, but still have the overall simplicity and efficiency of an MT. And if the automated clutching was still lighter than an AT, then its a big win.
CA
Good stuff here. Be sure to also watch part 2 of the link provided. Guy sounds like Mike Rowe
