How To Take Off This Towel Bar End?
Toronto, Canada
Do I cut in around the edges with an Olfa knife as much as possible and then drive the end up with a mallet to release it from a bracket behind it?
NO, no, no! You don't need to cut anything to remove the lucite plastic towel bar from the end mounts. Look at the end of the bar closely and you will see that there is a rectangular "insert" inside the bar at both ends. The "insert" is made of clear flexible plastic similar to polyethylene (think plastic shampoo bottle) that is friction fitted inside the towel bar. There are two ways to remove the bar:
Method #1- grab the square towel bar and pull it towards the left end bracket to expose the "insert" on the right side, then use a X-Acto/Olfa knife with a pointy tip to slide the "insert" left fully into the towel bar. This should give you enough clearance to clear the ceramic mounting bracket.
Method #2- if there is not much clearance to pull the towel bar to the left end bracket, you might need to use a sewing needle or dental pick to tediously pry the "insert" into the towel bar to get adequate clearance from the ceramic mounting brackets.
EDIT: If you are trying to remove the white ceramic end brackets instead of the towel bar, those might be attached with construction adhesive.
is it made of porcelain or ceramic? it looks like the old fashion kind that would have been grouted into ceramic tile work. maybe someone got creative and adhered it to the drywall/plaster
It looks like ceramic, doesn't have the gloss that I think porcelain has.
Elderly customer wants me to remove the towel bar and install a grab bar. There is going to be significant damage to the drywall if it is adhered to the drywall. I will let my customer know before I try to remove it.
towel bar kind of high for a grab bar, no?
You’ll want studs to mount a grab bar if not possible I’ve used these togglers for grab bars tv mounts and even wall cabinets.
Togglers
Togglers
^^This, but stud if available is better.
I assume this "contractor"/handyman has a stud sensor. :unsure:
How much does this elderly customer weigh?
A grab bar would have a 3 - 4" trim ring at the wall so that should cover up any damage.
One of my formerly teenaged sons removed one. When I asked what happened, he said “I dunno.” Drywall repair.
PicA grab bar would have a 3 - 4" trim ring at the wall so that should cover up any damage.
Lowe’s sells grab bars both w/ & w/o the trim ring. 😵‍💫
W/o
W/
Happened to me elderly friend purchased the bars ahead of time he didn’t realize and bought one w/ and one w/o. As Lowe’s calls it concealed vs exposed screws.
Check underneath for an allen screw, otherwise tap on the bottom with a mallet.
EDIT, yes if thats caulk , cut around it with a utility knife.
Look for two small recessed screws. Many times they are the same color as the bracket and not readily apparent. If it's not held on by double sided adhesive and you hit it with a mallet it can damage the drywall and the bracket.
the towel bar may sit on a tapered flange screwed to wall, take a rubber mallet after removing any caulk and pound upwards. evenly at ends.there may also be some tiny screws under the ends of bar bracket, with a tiny, slotted screw.
Yep. I see these alot in tiled areas.. It is what it is perhaps just get a piece of oak or a painted section of pine to cover it up then mount the bar to that. I've done that before and the next time I paint, I remove the wood and fix the wall if it looks tacky but I find its fine most times.
