Honda GCV190 motor oil
NY
I have a Honda GCV190 motor on my HRX Honda push mower. The manual calls for 10w30 but I have a ton of Mobil 1 5w30 EP. Has anyone else done this? I don't know enough about the motor to know if it picky about changes to the oil... I live in the northeast...lower NY area. Thanks!
ROCHESTER, NY
Yes! All I have ever used in my Honda 160-190 mowers(or any B&S, Tecumseh) is 5w30 conventional or synthetic, it doesn't matter.
Kingston
Same here with my Briggs and Stratton engines, my newest a 99 and my old 81 both worked perfectly fine on 5w30 synthetic (what I usually had around) or anything else. No difference between them. The 81 only failed from a catastrophic sudden stop (hit a large bolt in concrete under the weeds). It didn't smoke at that point and had about 25 years of heavy use (left unused for about 10 years in between). Originally it ran probably straight 30 changed every few years at best. I switched to synthetic twice a year changes to help extend its life. It didn't seem like it would ever wear out until I hit that bolt. I don't know the history on my 99 but it smokes on every cold start and immediately clears up. The oil stays looking like new for a full year of use now. Anything xw30 or xw40 would be fine in these.
NY
Great thanks...appreciate all the info. All my current vehicles use 0w20 and I would hate to waste perfectly good oil.
Vienna, Austria
my old Briggs and Stratton ran fine on straight 30, 5W40, 5W50, 10W40, 10W50, 15W50 - not a real difference noticeable. My new Honda GCVx 145 had Delvac conventional HDEO 15W40 for the first hour, then changed to Fuchs 15W40 conventional and will change back to Mobil HDEO 15W40. Maybe I'll try Delvac 1 5W40. Superb mower engine so far!
4WD
Texas
Have 4000w to 7500w gens on the Delvac 1 5w40 … find them easier to pull start with 5w …
Somewhere in time
It seems that with small OPE, the viscosity is nearly meaningless. Just keep it reasonably PM'd and don't let it run low and they tend to last nearly forever.
Vienna, Austria
Originally Posted by Hombre909
I have a Honda GVC160 mower running Redline 5w-40.
I was thinking about Motul 300V 15W50 - but then on the other hand why? 1.) It's a Honda 2.) It's not overly stressed running at 2800 or 2900 rpm mowing for 1-2 hours at the time 3.) HDEO 15W40 with enough zinc even in that aircooled engine is more than enough protection, to step it up maybe I'll use Delvac 1 5w40. I find no difference in starting the Honda GCV at all with different oil weights, Honda's easystart one (max 2) slight pulls and it runs.
Central Wisconsin
Being air cooled and splash lubricated I prefer a HDEO oil. I run Rotella 5W-40 in the push mower and just this week got some of the new Rotella 15W-40. Both synthetic. My 2¢
Vienna, Austria
Originally Posted by dwendt44
Being air cooled and splash lubricated I prefer a HDEO oil. ......
The GCV series isn't only splash lubricated, the internal rubber timing belt also ditributes oil. That's why they - at least unofficially told by a shop - are suitable for steep mowing without engine damage.
ME
Awesome! I learned something today. Those clever engineers...
Kingman, Arizona
I put Shell Rotella 15W-40 in the Honda GCV160 on my mower this time around because I had some left over, but I have used Rotella T6 5W-40 and 76 10W-30. I don't think Honda engines care as long as they have decent oil and the correct amount of oil in them. My engine has been running since 2003 and it doesn't use any oil even after 17 years of service.
usa
I have same and use German Castrol 0w-30
