Quote:
1) Can an ordinary hydraulic filter be used in this way? I'd find one with the best micron rating. At the reduced flow of an engine oil system, compared to the high flow rating in a hyd system, it should even step up a little in efficiency.
Well, yes. I don't think it will pay in terms of longevity at the level of filtration that you desire.
Quote:
2) Is the micron rating the only criteria for filtering soot?
AFAIK ..as small as 2um
Quote:
3) Will the restriction of a fine filter and 3/8" hose/tubing be enough to prevent excessive oil pressure loss? Or do I need to restrict flow in some way? I'll install a mechanical gauge as a check in any case.
You will need further restriction. A 3/8 line can move a whole lot of oil at even moderate pressures.
Your hydraulic mount may have an integrated bypass valve it. This would not be suitable for a bypass filter installation unless the outlet restriction (or inlet, for that matter) attenuated the flow to either nearly equalize the pressure across the media ..or make the flow inconsequential even if that threshold was reached.
I guess if you could assure that it's down to a trickle
Here's about the finest I found in WIX in the 1-12 thread. Most do not x'ref to WIX.
Part Number: 51259
UPC Number: 765809512597
Principal Application: Dresser, Jacobsen, John Deere, New Holland, Steiger (Hyd. or Trans)
All Applications
Style: Spin-On Transmission Filter
Service: Transmission
Type: Full Flow
Media: Paper
Height: 5.500
Outer Diameter Top: 3.670
Outer Diameter Bottom: Closed
Thread Size: 1-12
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 420
Max Flow Rate: 12-16 GPM
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.275
I don't know how long it will last under those conditions.
Here's everything Donaldson has in the 1-12 thread. The finer filtration numbers are in their SYNTEQ line. They would be prohibitively expensive for your frequency of service ..as I suspect hydraulic filters will be over some other type of filter - long term.
P179089
LPS04 ELEM 1/CTN
A - OD (Inches) 3.66
B - Thread Size (Inches) 1-12
C - Length (Inches) 7.87
D - Gasket OD (Inches) 2.81
E - Gasket ID (Inches) 2.42
Product Type Description HYDRAULIC SPIN-ON
Primary Application Donaldson LPS04 SPIN-ON
Media Type Synthetic
Efficiency Beta 2 (Micron) 2
Efficiency Beta 20 (Micron) 7
Efficiency Beta 75 (Micron) 10
Application Note 10 MICRON ABS. SYNTHETIC MEDIA
P550229
ELEMENT, HYD. SPIN-ON
A - OD (Inches) 3.82
C - Length (Inches) 7.01
Primary Application LINDE 009830615
Media Type Cellulose
Efficiency Beta 2 (Micron) 20
Relief Valve Setting (PSI) 30-42
P550230
C - Length (Inches) 8.23
Primary Application ZF 0750131007
Efficiency Beta 2 (Micron) 15
Relief Valve Setting (PSI) 32-38
P550255-288-140
LPS04 ELEM/REPLACES P564050
B - Thread Size (Inches) 1-12 UNF-2B
C - Length (Inches) 8.6
D - Gasket OD (Inches) 2.82
Primary Application GRESEN, MFP, CROSS, Donaldson
Primary Application 2 LPS04 ASSY
Efficiency Beta 2 (Micron) 10
P550274
LPS04 ELEM 12/CTN
A - OD (Inches) 3.73
C - Length (Inches) 5.76
Primary Application ZINGA AE-100, Donaldson LPSO4
Media Type 100 mesh
Efficiency Beta 75 (Micron) 149
Application Note 150 MICRON
P550591
HYDRAULIC SPIN-ON
A - OD (Inches) 3.68
C - Length (Inches) 8.29
Primary Application VOITH 90610310,
Primary Application 2 DYNAPAC 499519
P550695
HYD FILTER
C - Length (Inches) 6.83
D - Gasket OD (Inches) 2.83
E - Gasket ID (Inches) 2.45
Primary Application PETERBILT 10-960
Efficiency Beta 2 (Micron) 26
Efficiency Beta 20 (Micron) 41
Relief Valve Setting (PSI) 20-24
P550786
HYDRAULIC SPIN-ON
A - OD (Inches) 3.71
C - Length (Inches) 5.97
Product Type Description HYDRUALIC SPIN-ON
Primary Application LINDE 0009830633
Efficiency Beta 2 (Micron) 7
Efficiency Beta 20 (Micron) 17
Efficiency Beta 75 (Micron) 22
P551234
HYDRAULIC SPIN ON
A - OD (Inches) 3.67
C - Length (Inches) 5.66
E - Gasket ID (Inches) 2.46
Primary Application JOHN DEERE RE17380
Efficiency Beta 20 (Micron) 23
Efficiency Beta 75 (Micron) 35
P551550
CARTRIDGE SPIN FILTER
C - Length (Inches) 5.35
Efficiency Beta 2 (Micron) 4
Efficiency Beta 20 (Micron) 12
Efficiency Beta 75 (Micron) 16
Application Note 3 MICRON
P551551
SPIN-ON HYD ELEM
B - Thread Size (Inches) 1 - 12
Primary Application GRESEN, CROSS, DONALDSON
Efficiency Beta 20 (Micron) 21
Efficiency Beta 75 (Micron) 25
Substitution 25 micron version P551553
P551553
SPIN-ON HYDRAULIC FILTER
Primary Application GRESEN,CROSS,DONALDSON
Efficiency Beta 2 (Micron) 25
Efficiency Beta 20 (Micron) 35
Substitution 10 micron version P551551
P551756
HYDRAULIC SPIN-ON
C - Length (Inches) 3.79
Primary Application IHC 404886R1
P551780
HYDRAULIC SPIN-ON
C - Length (Inches) 7.35
Primary Application KUBOTA 35861682630
P552410
HYDRAULIC SPIN-ON
C - Length (Inches) 8.232
D - Gasket OD (Inches) 2.834
E - Gasket ID (Inches) 2.462
Primary Application Deutz 4305722
P560693
HYD SPIN ON ASSY
A (Inches) 3.66
A (mm) 93.0
B - Thread Size (Inches) 1-12 UNF-2B THREAD
C (Inches) 5.35
C (mm) 136
Primary Application LPS04 Series, 10 micron
Primary Application 2 abs Synteq., 5.35'' long
Efficiency Beta 1000 (Micron) 9
P563762
BLANK GENERIC SPIN ON
Product Type Description Hydraulic Spin-on
Primary Application SPE-15-10 BLANK
P563763
BLANK GEN SPIN ON
Product Type Description Hydraulic Spin-On
Efficiency Beta 1000 (Micron) 40
Element Collapse Rating (PSID) 100
P564357
HYD SPIN ON ASSY
Product Type Description HYDRAULIC SPIN ON
Primary Application DONALDSON LPS04 SPIN-ON
Media Type Sythetic
P564967
ELEMENT ASSY
Primary Application SPE-15-BTA-3
Efficiency Beta 2 (Micron) 3
P565059
ELEMENT ASSEMBLY
Product Type Description HYDRAULIC FILTER SPIN -ON
Primary Application DONALDSON LPS04 SERIES
Primary Application 2 HYDRAULIC FILTER ASSEMBLIES
P565060
ELEMENT ASSEMBLY
P565061
ELEMENT ASSY
P565062
ELEMENT ASSY
Product Type Description Hyrdaulic Spin-On
Media Type Syn/Cellulose
Efficiency Beta 2 (Micron) 5
Efficiency Beta 20 (Micron) 15
Efficiency Beta 75 (Micron) 20
P566040
ELEMENT ASSY
P566041
ELEMENT ASSY
P567849
SPIN ON ASSY
Efficiency Beta 1000 (Micron) 6
P763577
HYDRAULIC SPIN-ON
A - OD (Inches) 3.81
C - Length (Inches) 8.15
Primary Application ATLAS COPCO COMPRESSORS
Efficiency Beta 2 (Micron) 27
In your situation ..I think a tp filter would work well ..as would a home grown cotton wound filter. That's if you want to stay generic. You're looking @ about $150 in initial costs, but the media is cheap for what you get out of it.
