Originally Posted By: horse123
HM oils serve a purpose if you have car that leaks or consumes oil. In some instances a HM oil can help. Having said that if your car doesn't leak or burn oil there is no reason to use a HM oil, even if you have high miles on the car.
Typically but not always they're formulated a little more on the thicker side of the grade. Formulation is slightly different with more agents for helping with older seals that might be leaking, and they might clean a bit better.
I'm pretty sure high mileage oil means it can last something like 10,000 miles or whatever they claim... not that you use it on vehicles with a big number on the odometer
No, they are geared toward vehicles with high mileage on them.
