Here it is, first Rotella Gas Truck 5W30 VOA
Originally Posted by Snagglefoot
Here is how Rottela Gas Truck stacks up against some other SOPUS products including the new Pennzoil Platinum Ultra. Let me know if you see any errors. Some Data is missing and all the data is taken from VOAs from this forum.
Interesting to me that there seems to be a correlation of some kind between magnesium and boron levels...
Between the multi vehicle and the gas truck oil , going by the voas listing the additives, which oil would be better at protecting against lspi? Does multi vehicle carry Dexos D1G2 ?
I've never personally been able to locate Multi-Vehicle for sale in the States. I stick to commercially-available oils that I can either pick up or order on a whim for delivery inside of two days.
A distributor would definitely be able to help you. We do have to remember though, despite the name and the marketing, it still is a fleet oil, most useful to mixed fleets and certain builder approvals and/or applications needing E6. NAPA down south might be worth a check; ours have it listed.
Of course, I tend to purchase from a distributor, so have used fleet oils for an extended period.
Originally Posted by Virtus_Probi
Originally Posted by oil_film_movies
Highest HTHS I've ever seen in this category of 5w-30 (SN GF-5 dexos1) was https://www.sinclairoil.com/sites/d...01%205W-30%20SYNTHETIC%20MOTOR%20OIL.pdf Sinclair 5w-30 with 3.2 .....
There are many 3.1 ones out there. Typically 3.0, & few 2.9 ones.
Valvoline AFS 5W30 is also HTHS=3.2 per their website.
I'm thinking that MAG 1 and ST synth 5W30 are both at 3.15??
Castrol Magnatec 5W-30 is also a 3.15 HTHS.
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/4E042401C11971F980258297004677F3/$File/BPXE-9UE8M3.pdf
Castrol Edge 5W-30 (U.S.) comes in at a 3.04 HTHS.
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/CE9BF20358A9348E80257FAA00722E1B/$File/BPXE-AA5D3W.pdf
Castrol Edge 10W-30 (U.S.) comes in at a 3.2 HTHS.
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/329BC3613583AE7580257FBF00523113/$File/BPXE-ABJG4E.pdf
Originally Posted by Triple_Se7en
Is the Gas & Truck both SN Plus and Dexos1 Gen2 (on the jug label)?
Yes, dexos1 Gen 2 and SN Plus labeling are on the jug.
Thanks.
This oil in 5W30 is going on my Bucket List. Lets see, I see an opening for installment in Fall 2021. Booked solid until then.
Wait, G6 is coming. That might put the kibosh on Rotella Gas & Truck then. I don't want a large inventory when G6 arrives.
