Grounding/HyperGrounding Kits
TN
I haven't seen this topic come up before.
So, my Maxima is now 7 years old. Still runs like new, no funny sounds, just a few squeaks from the interior on cold days. I'm still very happy with the car...que "time to change something music".
I'd been thinking about adding a grounding kit, figuring that there was probably some parasitic loss in grounding over the years (dirt, old wires, etc). I got a kit from a car board I frequent that has excellent build quality for 1/2 the price of the other brands (Stillen, Nismo, etc).
Kit went on easy enough. One strand from ground to starter, one strand from ground to negative terminal, one strand from ground to engine block, one strand from ground (firewall) to upper intake manifold, and one strand from ground to timing chain housing/heads.
I didn't really notice anything. I keep the car (and engine bay) spotless and try to give everything a good degreasing and dress once a year with protectant.
Now the weirdness...when the engine is cold I'm getting a tapping noise at low RPM. I know I've done nothing other than ground the engine, so I'm sure it is either a loose bolt from the kit or a vibration/pulse being transmitted into the firewall. The tapping is rythmic and increases with RPM. It has a somewhat raspy sound to it. Once I get to work, I can barely hear the noise, which tells me the engine bay is now hot and the bolts/wires have expanded.
I went back over the install in detail yesterday evening. I had a 6th ground attached to the alternator on the bracket that secures the OEM ground. Thinking that was the only thing turning with the engine, I removed it. I also tightened all the bolts, adjusted wires that were in contact with anything, and used a zip tie on any wires that were loose. This morning the raspy tapping was still there. I'll be pulling the wires off one by one this weekend trying to track it down.
So, anyone have any experience (good or bad) on grounding kits?
They are 95% hype IMO.
I DIY the job using 4g wire and 6 grounding points. The ONLY reasons for doing this is 1) for looks and; 2)to eliminate the shock I got everytime I would exit my car.
Oddly enough, my motor required 2 less revolutions after installing the wires. Is was worth it to me because it cost me under $5 out-of-pocket, and Id do it again for the same price. If you are spending $30-$75 (hahaha!), I say save your cash.
I cant believe that changing/adding grounding points would have any effect on noises from the engine.
While seeking some advice in regards to this ground wire upgrade, I was given the warning to use only the same number of ground points that are originally on the vehicle.
Why exactly would this would matter, -is a good question...
There must be something to it. ECU related, maybe.
Did the new ground eliminate the "shocks?" Every time I get out of my car, it's as if I just entered a Schick Center!
Originally Posted By: DmanWho
..Did the new ground eliminate the "shocks?" Every time I get out of my car, it's as if I just entered a Schick Center!
Well, before the kit install, I would be shocked 99% of the time...the spark was so large it was clearly visable during the day!
After the install, I would be shocked maybe 10% of the time.
Since then, I had a ney key made that did NOT have a plastic "fob" on the key itself - its all metal .That way everytime I remove the key from the ignition I am grounding myself out through the car. I havent been shocked for over a year now.
That's fascinating. I'm not using a key in the SX4. (Smart Pass keyless entry.)
I'll move this up on the to-do list, before I become one of those freak gas station explosion statistics.
Originally Posted By: Anduril
I'm sure the engine noise is just coincidence.
When I got home yesterday, I removed the ground going from the firewall to the intake manifold. That ground is attached to a metal bracket on the intake manifold that also holds a wire clip. I also removed the ground going from the timing chain housing to the passenger fender well.
This morning the noise was gone. I think the noise was due to the stiffness of the wires allowing a transmission. It was not transmitting any type of frequency change in the radio.
I'm pretty sure it was the firewall ground.
