Good trailer repair place in Houston area?
Houston, Texas
Anyone know of a place that can change out the axles on my landscape trailer and do the job right? I'm thinking of putting torsion axles on and moving the fenders higher if necessary. Seems to be the easiest fix.
The Midwest
You really want to spend all that money to make the floor a few inches lower? You seem to make problems out of things that don't bother 99.9% of anyone else.
In the shop
+10,000
Upstate NY
Why - are current axles damaged?
USA
Commissioning someone for custom work and then hoping that they do a good job and the finished product meets your expectations is never "easy" and usually not cheap. The easy fix is to shop for a trailer that is already built and meets your usage case better then trade yours for it.
Worst Case, Ontario
The easiest way would be to DIY, you don't need to be a pro mechanic to change axles on trailer.
motor_oil_madman
Houston, Texas
The trailer being too high isn't the only issue. It's the axle to frame clearance that is the issue. THE axles pretty much rest against the frame.
Phoenix, AZ
Is it spring under or spring over?
motor_oil_madman
Houston, Texas
Under. If we put the springs on top of the axle the trailer would be too high to load anything on
