I rarely ever see gasoline filters with any useful information advertised (micron rating/efficiency, media/housing material, holding capacity, flow rate). I reached out to a couple dozen brands to do a survey, but the results have been very disappointing so far.
I was thinking instead that it might be worth just testing. Seems like it could be pretty straightforward. Buy some test dust in the 5-10 micron range, load an equal amount into each filter, run pressurized water through the filters while agitating them to prevent settling, then measure the particles that get through. Could probably measure by giving some time for settling, pouring off the majority of the filtered water, then letting the rest evaporate and weighing the remaining dust.
Brands to test that come to mind are ACDelco, Baldwin/Parker, Bosch, Carquest, Duralast, Ecogard, Fram, Mann, MicroGard, NAPA, Pentius, Purolator, and Wix.
Thought I'd check here first to see if that's already been done, or if there's a better way to go about it.
