Originally Posted By: mechanicx
Japanese coolant has always used phosphate to protect aluminum instead of silicates. Antifreeze bottles don't list every ingredient. Japanese coolant has always been a hybrid of phosphate and an organic acid. Just about all antifreeze contains some inorganic inhibitor and that's a good thing. Even Dexcool the first OAT and about the only OEM coolant that is an OAT and not a hybrid uses triazole which could be considered an inorganic inhibitor. I don't know of any OEM coolant that would just use benzoate and not at least another organic acid or an inorganic. Why do you think G-05 adds silicates, among other inorganic inhibitors, even though it contains benzoate? Benzoate alone won't cut it.
The link you gave itself explained that subaru recommendds a non-amine phosphated coolant. In other words, Subaru recommends inorganic phosphate coolant be used.
I agree with almost everything you have written in the above, except "subaru recommends an inorganic phosphate coolant"..I have never read on any subaru forum the interpretation that you have given concerning the "TB link" I provided above..borrowing from another subaru forum..the General understanding is..(("subaru says to use phosphate non-amine coolant".However,their own coolant contains No phosphate but rather uses by the "trick of chemistry" , they say, sodium benzoate to do the same thing that phosphates can))" and then adding Potassium hydroixde..also, I have it hard to understand, that if subaru puts out a TB stating you will not find phosphate on the ingredient label, ...what else am I going to think??..that subaru is going to add phosphates anyway?? (Peace).. Hopefully back to the original topic..Do you have any further thoughts or insights concerning the same NJTS# for the 50/50 G-05/Asian
