Funnel for very small openings? (Like Honda ATF refills)
PA
Anyone have a longer, very tiny diameter funnel they're happy with? Seems like amazon should have something but haven't found one that seems like what I want. I ruined the homemade one I've been using for years in an attempt to make more ideal. This would be mostly for Honda ATF changes through that near pencil-sized dipstick.
For ATF changes on Hondas where you must fill through the dipstick tube, I use a long neck funnel with a 8" section of commensurate diameter clear Tygon PVC tubing attached to the bottom as a transition adapter.
The i.d. of the tubing must fit snugly on the o.d. of the dipstick tube to preclude leakage. It takes a long time to fill because the displaced air must simultaneously burp out as the ATF enters through the tubing, so I usually hang the funnel on the hood with a wire. For the very narrow dipstick tubes, you may need to use a small funnel and narrower Tygon tubing.
I also found this funnel listing on Amazon that might work for you; however, the narrow tip opening dimension is not identified.
What Hondas use the dipstick for refilling ATF anymore ? Going back to a '99 4-cylinder, even that used a 1" or bigger fill port. Our V6s and R18 4-cylinder use the same design.
  • Like
Reactions: JTK
I have these in 200 & 500 - removes and replaces fluid very well …
https://www.ebay.com/itm/1454239788...twYtV+Edw==|tkp:BFBMqufB3clk&var=444604792543
I got some that were for a science lab. The opening is about the size of a straw.
That is the perfect size end. Looking around for something Honda specific, I'm reading my V6 Accord has a large plug that is removed to fill the trans. Wish I had known this 15 years ago when my parents bought it.
Try the Flotool 05034mi -- it's that long black funnel from the auto parts stores. I had one (mine might have been made by Blitz, but I think they are identical). It fit snugly right over the tube (dipstick?) on the Hondas I had.
You can always put a length of tubing onto the end of a funnel...
Can buy different sizes at H.D. and Lowes . Just bought some for A.T.F. fluid change to attach to a long neck funnel to reach the fill hole of the FIT .
