Originally Posted by Rand
Originally Posted by 1978elcamino
Lots of folks try t6 5w40, 5w30 and motorcraft 5w50. I personally have tried MC 5w30 and currently in there I have t6 5w40. I think next change I would like to try a 10w30. Is there a sn+ 10w30 out there?
Seems like you want a "thick 30" oil this isnt determined by the first number a 5w30, 10w30, or even 15w30. would all be relatively similar and the 10w30 could be the thinnest of the 3.
Arco posts without his meds frequently so if something looks wacked out I usually just ignore it, The other day he was quoting himself form another forum and calling it wisdom.
If you want a thick 30 you are better off mixing a couple quarts of 10w40 with the same additive package to your preferred 30wt oil..
an example would be using 2quarts 10w40 in place of 2 of your quarts (of 10w30 or whatever)
making sure its the same brand. ie not mixing shell and Mobil 1.
You are g-d. I bow to thee. forgive me my sins.
You know HTHS is the major variable in play here due to fast sharing VM used in ILSAC fluid for fuel economy reasons.
Also thank you for continuing the confusion using the not preferred term "wt" for "grade".
Oh, Continued ad hominem attacks from the feeble will not be tolerated.
Bye!
- Ken
Bye!
- Ken
