FS Solar panels PU only 250w $80
FL
For the BITOG folks. I have used 250 watt solar panels for pick up in the Tampa area. These are in great shape and have plenty of life. Labels have been removed so these are for off grid. $80 All have been tested and are working. For those that don't know solar panels degrade so these most likely will not put out 250w but they had 25 year output warranty (to the original owner) so they still have plenty of life. Rated Power: 250W Open circuit voltage (VOC): 37.6 V Max power voltage (VMP): 30.3 V Short circuit current (ISC): 8.85 A Max power current: 8.27 A Power Tolerance 0/+3% Maximum system voltage: 600V (UL) Fuse Rating: 15 A IP65 Junction Box w/MC4 Compatible Connectors Frame: Anodized aluminum alloy Weight: 41 lbs Dimensions: 1650 × 992 × 35mm (64.95 × 39.05 × 1.37 inches) No Shipping , sorry these are to big and bulky (unless you want a pallet full smile ) If things ever get back normal I will be able to deliver around the state of Florida especially south Florida.
