FlyNavyP3
Originally Posted by A310
Very nice install Luke, your oil pressure drop is very similar to my 6.4 Powerstroke and should not pose any problems. I'm very interested as well to see how long your filter lasts before it stops flowing. In an attempt to extend my filter duration, I've switched from Kirkland brand to Scott 1000's as well and see if I can get another 1000 miles out of the roll.
Thanks A310! The stainless braid is likely way overkill but it should be durable and went well with the existing remote oil pressure sending setup I already had to run my stock gauge and Autometer gauge.
I have about 80-100 miles on the system so far, idle oil pressure is more or less unaffected (down 2-3) but cruise pressure is down more like 8-10 psi the bigger surprise to me was high speed cruise oil pressure. Before the bypass it was 75-80 usually closer to 75 which is the bypass setting in the pump. When the oil is cold or not fully up to temp medium and high speed cruise still are 75 psi. However once the oil is fully up to temp high speed cruise oil pressure is down 15+ psi. It now cruises on the highway at 55-60 which is still more than enough but it bothers me a little after watching it cruise at 75 for 85,000 miles. This may be a function of how and where the gauge is plumbed in relation to the filter. Or it may be a reflection of the actual pressure drop due to the new controlled leak in the oil system and worn lower end bearings in the engine. I have a 0.035 inline orifice coming to install on the inlet of the filter as well as a plug and cap set to do some experimenting.
I will let you know if slowing down the bypass flow with a 0.035 orifice has any effect on the oil pressure.
