flat tappet.
Australia
Hi.
What exactly flat tappet cam mean? Cam systems on 1997-2002 Camry V6 or 5sfe engines are they flat tappets?
New low SASP oils drama applicable for these engines as well? Any photographs on flat tappets here?
Thanks in advance.
I think that they are roller cams, I am sure that GM went to rollers in 1987, and I would think that Toyota did too.
I would Google Flat Tappet Cams and you will find out all of the info you need.
Originally Posted By: toyota62
http://z.about.com/d/autorepair/1/0/s/S/42124617.gif
is this flat tappet?
Yes, that looks like a flat tappet cam, a roller cam is perfectly round, whereas a flat tappet cam kind of has a cone head look.
My guess is that`s a roller cam,right?
Close. The Buick V6 was still using flat tappets in '87 but went roller the following year in FWD form.
You can't really tell by looking at the cam as they're both cam shaped lol.
The roller cams usually have a more aggressive ramp so the nose of the lobe will look a little flatter. Still can't always tell by eyeballing it.
Obviously the lifter is what you want to look at. The flat tappet (or lifter) has a flat bottom (the portion that rides on the cam) and the roller lifters have a roller built in. For this reason the roller lifter must be kept from rotating while a flat tappet lifter is supposed to rotate in it's bore. There will be extra hardware to keep the roller lifters straight in the bore.
The diagram shows what would be called a "flat tappet" because it has no roller between the cam and lifter.
the lifter on the right is "flat" while the one on the left is a "roller"
And note the flat spot near the top where the hardware attaches to keep it from rotating. Nice illustration.
Then even 2009 toyota camry 2.4L engine still have flat tappet.
Low ZDDP engine oils effect on these engines as well?
It's overhead cam so spring pressures are less for a given engine. I would say ZDDP is not as important as it would be in a pushrod engine.
'' It's overhead cam so spring pressures are less for a given engine. I would say ZDDP is not as important as it would be in a pushrod engine.
BuickGN.
Thanks a lot mate.....
It is the high performance factory and aftermarket cams/lifters that can need extra help with break in.
In a valvetrain, you have a roller or a flat tappet, whether overhead cam or pushod.
The valve springs will be wimpy soft pressures enough to control the valve from bouncing and floating.
In my old pushrod motor in my 1965 beetle (11's in the 1/4 mile)I use chevy springs. Aprox 150lbs seat pressure and aprox 380 lbs at the nose of the cam on full lift. Using tool steel lifters requires NO breakin on a virgin engine.
For over head cams you have NOTHING to worry about.
