I purchased a gallon of Evinrude Engine Tuner, part number 777189. It is a honey colored liquid. I intended to add it to my fuel / oil premix. The label on the back of the gallon container says not to leave it in the engine. I can not add this to my built in 50 gal fuel tank if the mix can not stay in the engine. The engine is a 1997 Evinrude 115 Ocean Pro. It has been converted from VRO to pre-mix. The engine is on an 18' center console (Ranger) boat. I have read every topic I can google, but nothing found on how to use this liquid tuner. If it needs to be sprayed into the carbs, what sort of sprayer would I need?
Has anyone used the liquid/gallon Engine Tuner, if so, how? Again, this is not the aersol cans, but a gallon of liquid. Lots of discussion available o the OMC engine tuner aerosol cans and Sea Foam. I am seeking any experiences with the liquid. How did you use it, how did you get in into the egine. I am considering the Sea Foam method - add 16-20 oz of the tuner, 4 oz of oil and fill a 1 gallon jug. Run this through the engine on the lake, let is set for 30 minutes, then reconnect the main tank and run the egine.
I posted this on iboats.com and have not had much response from people who have actually used this. Sorry if you saw this post there.
thanks for any input.
