Ecogard S4477
Des Moines, IA, USA
Anyone used this filter in the past? I emailed Ecogard for the specs and this is what i received: Height: 3.66in Length: 2.68in Width: 2.68in Thread Size: 3/4"-16UNF-2B Anti Drain Back Valve: Yes Bypass Relief Valve: Yes - Opening Pressure 15psi Filter Media: Synthetic Blend Filter Effeciency: 99.8% @ 20 microns. Do I need to be concerned about the Bypass Relief Pressure? I noticed the WIX recommended for my car(2012 Suzuki SX4 AWD) is rated at 18PSI.
Katy, Republic of Texas
The Fram equivalent (4386) is at 14 PSI. I would not worry about it all that much. There are quite a few filters that give a 4-5 psi range for the bypass. I see it is less than $5 on Amazon right now, not a bad price for one. They are about on par with a Fram Tough Guard or Mobil 1 and such (synthetic blend media, nitrile ADV). I have used them before and would use one again at that price (but they are $9 for my applications at the moment).
WA
The S5848 10k filter is about $8 for mine. Cheaper than the M1, Purolator or Fram Ultra for my app. I only do 4k oci's so I just go with a Wix, Fram Extra Guard, Champ Labs or even the Ecogard conventional. The OE M+H for Hyundai are my "preferred" when I can find a good price on them.
Outer Banks, NC
To the OP: welcome to you, and I wouldn't fret about that small pressure difference.
Correction: the S series has a silicone ADBV. The X series has a nitrile one. The S series at $5 is a good value.
duh I knew that. thanks for correcting it.
