When I installed the Frantz filter, I replaced the full flow oil filter without changing the oil. I pre-filled the FF oil filter and Frantz canister without adding anymore oil to the engine. I checked the oil dip stick right after engine turned off. It showed oil level well passed the maximum mark.
When the engine is turned off, will there still be some oil pressure left in the Frantz canister that pushes the remaining oil into the engine? The Frantz filter sits lower then the oil cap to where the oil is returned.
