- Joined
- Feb 27, 2019
- Messages
- 631
Let's say I already use a GF6/D1G2/SN+ oil and my car is 91 recommended. Will running 93/94 further reduce the chance of a LSPI event occurring?
Yes, it definitely stopped the pinging in my 15’ Sonata.
traditional pre-ignition/pinging/knocking is not exactly the same phenonomon as lspi
So while higher octane helps. using the right oil that doesnt promote lspi also helps.
This.Lugging the car can also cause lspi so dont push it at low rpm and high gear, i assume this is worst with a manual transmission, an automatic transmission will normally choose a lower gear by itself.
Actually, the modern autos/dual-clutches are brutal for this - they upshift v. quickly and require at times a lot of pedal input to shift down. One has to think that LSPI has been considered by the manufacturers in their shift map logic.Lugging the car can also cause lspi so dont push it at low rpm and high gear, i assume this is worst with a manual transmission, an automatic transmission will normally choose a lower gear by itself.
Yes thats true, i have a 2013 BMW and it is just like that, at least in normal "Drive" and comfort mode. I drive it in sport mode to get the transmission to choose a lower gear. Another difference from older automatic transmissions is that its always in lockup and every 8 gear got lockup. My old GM 5L40E got in lockup just on 4th and 5th gear when the speed was over 50 mph, guess the slippage in old transmissions was good in some wayActually, the modern autos/dual-clutches are brutal for this - they upshift v. quickly and require at times a lot of pedal input to shift down. One has to think that LSPI has been considered by the manufacturers in their shift map logic.
Yep....I use the paddles and sport mode in my DSG to keep things moving along at times. I have a DSG software tune also that helps with the premature upshifting.Yes thats true, i have a 2013 BMW and it is just like that, at least in normal "Drive" and comfort mode. I drive it in sport mode to get the transmission to choose a lower gear. Another difference from older automatic transmissions is that its always in lockup and every 8 gear got lockup. My old GM 5L40E got in lockup just on 4th and 5th gear when the speed was over 50 mph, guess the slippage in old transmissions was good in some way
How much difference in cost 91 vs 93? Run a couple of tanks in it, see what it feels like.
Not sure why it's worse with a manual when it's all driver based. Automatics are always tuned for fuel economy and will try to be in the tallest gear possible. Some owners manuals even say some slight knock is acceptable as that's how you're maximizing fuel economy.
That's like saying a BMW M5 is more dangerous than a BMW 3 series because it can go faster quicker.
Lspi is "superknock" that can destroy an engine. I mean the manual transmission is the worst because at some point an automatic transmission will take over control even if you drive it in manual mode if you forget to change to a higher gear when passing the redline to much. At least my 2 Bmw's with automatic transmission does. But i am not sure if it force a lower gear when driving in manual mode to avoid lspi if the rpm is to low and the throttle to high in a high gear so maybee there is no difference but i have never tried that way
But I'm just wondering if buying 93/94 fuel is worth it if there is additional protection against LSPI. This is on top of using the best oil for it available.
