Originally Posted by nthach
There's also single-din CB radios too, if you go off-roading a lot, it'd be stupid not to have one as it's the only thing that works where cell phones don't.
Not able to change to double DIN; they are slightly offset. I mean, I COULD but I'd have to hack/shim/create a trim panel for the bottom. I'm not THAT into it though I agree a double DIN could be more practical these days.
I like the CB idea. I do go once in a while out of cell phone range around here. Not a lot, but a few times a year. I also have a spare antenna mount on my fender. I have both an in-window antenna for the radio, and I have a fender-mount mast antenna that is not connected to anything.
The reason I made this post is what people have pointed out - a simple "blank" cubby, things are going to fly out/slide out. A drawer unit, which would be great, would be inaccessible in Park and it would be annoying to not be able to open it w/o a key and stepping on the brake to shift if the vehicle isn't in motion. I had thought about instruments, but it's down low and you wouldn't be able to see them well. I did add an aftermarket GlowShift Trans Temp gauge a few years ago and put it in an A-pillar pod and like that.
I'm going to look how much a single-DIN CB costs and think about that - interesting idea.
