Chevy Camaro rear Diff fluid
Originally Posted by s2krunner
Also Do you guys think Redline D4 ATF also great choice for Manual 6 spds?
I have to look it up but i think its recommended Dexron 3.
Thanks
It depends which 6 spd you have to which fluid is recommended.If you have the MJK, MH3, or MM6 it calls for Manual Transmission fluid Part Number 88861800
If you have the M13 6 Speed it calls for Dexron VI or Part number 88865601.
Its TR6060. Its recommended Dexron 3 if im mot mistaken it
TR6060 is a MJK Transmission. I work for general motors. MJK transmission calls for Manual Transmission Fluid 88861800.
EDIT FOR ADDED INFO-
MJK
TRANSMISSION-MAN 6 SPD, TR6060, 85MM, 2.28 1ST, 1.61 2ND, 1.20 3RD, 1.00 4TH, 0.81 5TH, 0.53 6TH
Thanks
MJK
Thank you!
Originally Posted by ARCOgraphite
Can you see out of these Camaros yet or is it still like desert storm in a M1A2 Abrams?
I mean REALLY!
It's really a non-issue once you adjust the seat and mirrors.
I would NOT change viscosity. Either use the GM stuff or the comparable Redline fluid.
I mean REALLY!
They all seem to run under 12 second 1/4 mile times at the drags who care what the behind vision is.
