Chemistry and Math Help
WDP
Eastern Pa.
I have scored 3 samples of Polybutene. 10.5 cst, 229 cst and 340 cst. Reasearch has shown that added to fuel, gas or diesel produces marked power and mileage increases while reducing pollutants. I have found mix ratios of 2 ounces to 10 gallons of fuel produces the desired outcome. The active PIB content of the carrier mix is 1%. My math (weak) says 15.6 PPM or .59147 cc in 2 ounces of carrier solvents, these 2 ounces mixed with 10 gallons of fuel. Does anyone know which weight polybutene should be used? And if my math is correct. Testing will begin after clarification.Thanks.
WDP
