wtd
Ok, I just went into network connections and right clicked on the ethernet connection to pull up the properties and un-clicked the IPv6 box. Is this the correct place to do this?
This issue can happen when I use Google Chrome as well. I usually use Microsoft Edge. Sometimes when I can't access the site through Edge, I can go to Chrome and it will let me in. Sometimes it won't and I get the same error message.
How do I know if I have a VPN? I have not personally installed one.
The router has been rebooted multiple times with no effect on this issue.
Flusing the DNS cache is only useful if the wrong address is being cached. Since he's having intermittent connectivity, that's not the culprit. All new queries would be routed through OpenDNS, which rules the router out as a DNS proxy screwing up the queries.
Can you explain the logic of how Window's networking stack prioritizes and retrieves each entry, how large that cache is, how often it's refreshed, and thus say with certainty that a bad one is not being still pulled from the cache?
If the OP changed their DNS servers but didn't flush the cache, how long would it take newer, and proper entries to flush out any potential bad ones from the existing cache? How does Windows decide whether to pull from the cache, or request a new entry?
What if the admins of the problematic sites improperly set their TTLs?
On the enterprise level, it's still allowable to have to wait 24-48 hours for a name server change to propagate. How fast does it occur on the local machine level?
Sure, but given the duration of the issue, the cache will have already expired multiple times at this point. My suggesting to use OpenDNS instead of the router was on the off chance that the router was intermittently not resolving queries.Flushing the machine's cache is easy, not going to hurt, and at least provides a clear baseline to work from.
That's a good suggestion primarily because it might cast some light on whether it was trying to get to the site via IPv6 or IPv4.I'd also suggest having the OP run a traceroute on the unreachable sites and see where it goes (and terminates).
And if the OP has a spare networking adapter handy, it could also be used to help eliminate a bad network card. My anecdotal experience includes two office Dells with network ports that died, and were replaced with network cards, though I don't recall if the failures mode was partial or total.
As I said, I'm not a Windows IT guy, so feel free to take what I say FWIW, but they are not uncommon troubleshooting techniques.
This morning I tried accessing my credit union's account access tab and got the error message. I just tried it now and it allowed me in.
For the last couple of days I have been able to access the bobistheoilguy website without getting the error message.
Yesterday evening I was watching a video on YT and clicked on the link in the description to read the newspaper article about the incident I was watching. It let me in to read it. I finished reading and clicked out. about five minutes later I clicked the same tab again to re-read something in the article and then it would not let me in and I got the connection error message. Refreshing the page did nothing.
Yes.And this is all with IPv6 disabled, correct?
Yes.
I am not familiar with the snipping tool and have never used it. How does it work?OK, so:
- We know it isn't hardware because it persists across two adapters, one wired, one wireless
- We assume it isn't the router, because your other client is fine
- It's intermittent and persisted for quite a while so it is doubtful to be in any way related to DNS
- You've disabled IPv6 and it is still happening, so we know it isn't protocol related
This leaves us at something on your computer interrupting the connections.
Are you able to use the snipping tool to capture what's installed on your PC under Programs and Features in Control Panel? If the list is long, it may take 2 or more snips.
I'm not finding a Programs and Features section anywhere. When I click the windows icon in the lower left corner it brings up a long list of stuff by alphabetical order and nothing is in there that I see. When I click on the settings tab I don't find it in there either.
Perfect, now click on "Programs and Features" there, which you can see is 4th from the bottom in the 2nd column from the end. That will give you a list of your installed applications. You can use the snipping tool to share that list here.This is everything under control panel.
