I hope this is the right forum.
I changed the hydraulic oil out on this oil at the CAT L&M guideline 2000 hours.
I recently put a Bypass filtration system on the HYD and ENG on this 950H.
I have been debating on adding bypass to the Transmisson.
Here is the last couple of samples on the HYD system. The oil has just under 500 hours of run time. I will probably just maint. the bypass filter and sample every 1000 hours. It will take a while to generate the hours.
Chevron URSA
If yall are interested in the UOA on the engine I can post it up as well.
Chevron URSA
