I currently have a B&M full flow filter that takes a single FL1A sized filter on my F-150. It seems to be working well. It adds capacity and some cooling in addition to the coolant loop that already exists.
I've been thinking awhile about this, and I am thinking about doing something similar on my 2002 Ford Taurus. However, since this car sees the vast majority of the miles we drive, I am thinking about going... bigger.
I do belong to this site for a reason, and the more I tinker with my Taurus the more room I find to hang stuff. Just that I am seeing that going bigger won't cost that much more, and...well... this site is about overkill.
I can either get the same B&M filter setup, the one that takes FL1A filters... and I could hunt down the foot long filters that are the same thread size and diameter, but hold around 2 quarts. Which would be great for long ATF drain intervals.
However, I am thinking about going larger.
There are other filter adapters out there also. Those that have a 2" threaded portion for relocating Diesel oil filters, and those that can hold 2 FL1A sized filters that are sold through Amazon.
I'm kind of thinking about going with the large Diesel oil filter attachment with the larger filters.
Living in Texas and using synthetic fluids I'm not worried about over cooling. I plan on keeping this assembly tucked out of the way so that nothing can strike it and it won't have that much of a breeze over it during movement.
I've been running Magnefine's on several cars I normally work on and flaring steel tube (using the correct double flare tool) and running extra line is now quite easy.
I figure that this will be several steps up and will increase the longevity of my transmission and be a fun project.
What are your thoughts?
Any other sources you can think of?
