I have a 2007 Escape XLS 2.3L ATX. A few months back the front disc brakes got new pads and turned rotors. It was done by a shop (yeah i know, bad idea). Anyway, I think the new pads are the duralast ceramics. The reduction in brake dust has been amazing. The rotors were turned and brake fluid was flushed at the same time.
Anyway, to the problem. I tried bedding them in when I first got it home. I didn't go full bore but was able to do some 30 to 5 braking about 6 or 7 times. The problem is when the brakes are cold, they have a really loud high pitched squeak or squeal like two hard surfaces coming together. After about 1 or two stops from 10mph and the noise completely goes away. Obviously, once the brakes warm up a bit, everything is great.
Is there any way to prevent the noise when the pads are cold or is it just nature of the beast?
