Brake Calipers for my 74 Corvette
Milwaukee, WI.
There are several companies out there that can bore yours out and re-sleeve with a stainless steel insert. It then uses std. components. Had this done to mine several years back and it works great. If I recall, it was SSB in New York that did mine.
Los Gatos, CA
You have 2 choices - rebuilt cores with steel sleeves. By now I doubt there are any original cores left. There are also new calipers; I have heard a good rebuilt caliper is the way to go. Lonestar is the supplier to most parts houses. Lonestar There are 2 piston tryes: lip seal (original design) and o-ring. The o-ring style is considered the better design. The hardest part of 65 thru 82 Corvette brake work is bleeding. I use a Motive Bleeder.
Connecticut
I have had calipers restored at Goldline Brakes and PMB Performance. The quality and service from both has been superb.
