On my 95 YJ a lot of detonation could go unnoticed due to the wind noise and other asst. noises the vehicle makesquote:
Originally posted by Virtuoso:
You would think you'd be able to hear that level of detonation...but maybe not?
I got spanked here by someone here on this. The leaner mixture apparently ends up burning off the insulating boundery layer of combustable material that clings to the interior of the cylinder/piston/combustion chamber. That allegedly exposes and damages those surfaces (mainly pistons and valves).quote:
Lean mixtures burn hotter.
air leak increases the amount of air versus fuel. Some efi systems tweak individual cylinders, but some dont. I bet this system since its older only tweaks all cylinders. So, add air to one cylinder thru a leak and you get lean mixture which drives cylinder temps very high resulting in a burned piston.quote:
Originally posted by wrangler:
stupid question but wouldn't an air leak increase the fuel to air ratio making it a rich mixture, which should run cooler? So an air leak would not contribute to breaking a piston.
If this was a leak somewhere centered on the plenum ..the engine would just either regulate it by the MAP output ..or the entire sensor array. If the leak (since this is a inline engine) is on one runner ..that cylinder will be lean. The O2 sensor would balance the entire mass of exhaust gases ..still leaving that lean.quote:
The DC MPFI uses two "batch fire" pulses to control injector firing in the 2.5 (three in the 4.0). This, I believe, is the current system in use (it was in the 99 FSM). So this engine should have had three somewhat rich cylinders ..to compensate for the lean one. This is a reliable ..but fairly numb FI system.quote:
quote:
I have to admit I drove the **** out of it thru the mountains... I would say I spent a lot of time in the 3500-4000 RPM Range, thru the whole trip, I have 32 and its not re-geared, however I ordered 4:88s a couple days ago
