AftermarketAre these husqvarna coils, or aftermarket?
They are after market dealer ones are 75.00Are these husqvarna coils, or aftermarket?
There might be an issue with a kill switch instead. There might be a lug connected to the coil, yank it off and see if spark appears before buying another coil. Did you ever test their resistance to see if a coil opened up? I encounter more kill switch issues that I do bad coils.I have a husqvarna 125bv x series hand held blower that keeps blowing ignition coil. Will instal coil it will work that time but when I use again coil is dead. I’m on my 3rd coil. Can anyone help?
I don’t understand what a lug is.There might be an issue with a kill switch instead. There might be a lug connected to the coil, yank it off and see if spark appears before buying another coil. Did you ever test their resistance to see if a coil opened up? I encounter more kill switch issues that I do bad coils.
NoDo they use an external ballast?
probably chinese junk....try an original coil with a different brand plug....Aftermarket
