If an engine is sucking oil thru the PCV (assume the PCV system is operating fine) due to blow-by. Is it better to retain the stock system and use a catch can or move the PCV system to the valve cover or it does not matter?
If the PCV system is no longer sucking oil then does the engine begin to burn it instead?
