Bentley GTC OEM, GC at 3,000mi & 6,000 mi
Sarasota, Florida
This is a Bentley GTC UOA at 1, 2 and 3,000 miles taken from the OEM oil. The first factory scheduled oil change was at 10,000 miles. My plan was to run a UOA every 1,000 miles for as long as I can stand not changing the oil or to 6,000 miles, whichever occurs first. No oil was added.
After the 3,000 mile UAO, at about 1 year of the cars life, I changed the oil to 0w30 Castrol GC. I ran the GC for 3,000 miles now and decided to test the oil twice, cold and then hot after driving for 30 minutes around town. The car was sitting for 4 or 5 days before the cold sample was obtained. We then drove the car. We came home and drew another sample hot.
The engine is a 6.0 liter twin turbo W-12 with 550 BHP, compression ratio 9:1, top speed - 198 MPH and 0 - 60 dash = 4.8 seconds. The curb wt. is 5,500 lbs., EPA 11, 24 MPG.
....................OEM Oil - - - - - - - - - -> - - - - New Castrol GC - -
Miles on car...1,000 mi.....2,000.....3,000.....6,000 cold...6,020 hot
Miles on oil....1,000.........2,000.....3,000..........3,000+/-.........
Iron___________22_______23_______33_______15____15
Chromium _____ Nickel _________1________2________2________1____ Aluminum ______5 _______7________6________4_____2
lead __________ 1________1________3________1_____2
Copper ________32_______34_______41_______7_____7
Tin ____________5_______3________3________1____ Silver ________ Titanium _______ Silicon ________ 37_______34_______39_______9_____9
Boron ________228______195_______219______17____16
Sodium _______ 15_______12________13______5_____5
Potassium _____ Molybdenum ____91______81________92_______7_____7
Phosphorus ____1027_____936______1035_____865___877
Zinc _________ 1151_____1027_____1182____1000___1026
Calcium ______ 3228_____2915_____3301____1780___1857
Barium _______ Magnesium ____22________21_______29______455____485
Antimony _____ Vanadium _____ Fuel %Vol _____1.5______ Wtr %vol ______ Vis CS 100C __ 12.3______12.1______12.1____10.9___11.1
SAE Grade ____30________30_______30_______30____30
Gly test ______Neg_______Neg______Neg_____NEG___NEG
TBN ________not done____NA_______NA______NA____NA
Abs Oxid______23_______27________29______14_____12
Abs Nitr_______10________13_______14______12____12
Fuel soot______NA________NA_______0.0_____NA____NA
Test lab was: youroil.net
aehaas
Wear came down nicely, but your 'run' doesn't sem to have burnt much of the fuel out of the oil.
I'm sure 3% fuel is nothing from a twin-turbo, 6-liter V-12. That is one big, powerful engine!
Awesome car. Awesome UOA. Always wondered the difference between a cold and hot UOA. I have been anticipating this thread. Are you going to stick with the GC for another UOA?
I will probably go another 1,000 miles then change the oil. I still have some GC to use up and it will be a year on this oil by then.
aehaas
3k miles in a year....
How would it be? (as his 3.5 year old car just passed 130k)
Take care, Bill
AEHaas, when you sampled at 1000, 2000, and 3000 miles, was this after a 20 mile drive? Why do you think your fuel is now up to 3% ?
"Why do you think your fuel is now up to 3% ? "
The last few trips were all less than 1 - 3 miles, the store, out to eat next door and to friends homes within the neighborhood. Half a dozen short trips from a cold start = fuel dilution. I tried to get my wife to drive an hour to Tampa and an hour back this weekend. I was then planning to get another UOA to see what happened to the fuel dilution. But the wife was not in a travel mood.
aehaas
aehaas
Did you offer to go with her?
Yes, I was going with the wife to Tampa.
This is sounding eerily familiar - when my wife's car needs a run to burn off the fuel and water load from short trips, it's a. not available because she needs it, or b. going for a drive with me is a wonderful idea, but maybe some other time...
I did another UOA after finally doing a drive to International Mall in Tampa, a total of around 3 hours on I-75.
The fuel dropped to The viscosity is now 10.9 - previously 11.1 with the fuel at 3.0.
This may help show that fuel dilution does not by itself have a big effect on the actual viscosity. It is the presence of fuel that hurts things inside your engine.
aehaas
and maximum instantaneous speed?
it's the carnage that fuel leaves behind, crashing oil, etc. that causes the problems
left unattended it will, of course, eventually affect the viscosity
