Battery terminal eyelets too large?
Central Ohio
Sorry for the super elementary question here…
I’m installing a maintainer and the eyelets are a little big for the posts. They are small enough to not slip over the nuts, but there is quite a bit of play. Is there a solution to this, or is wrenching it down gonna me ok?
Get a washer. If that oversized hole gets jarred, everything in that fastener, including the original stuff, becomes a loose connection. Alternatively, could you put the other wire, that's under the charging one, on top of it, so it sandwiches it all together?
I know it's just a maintainer but it looks there are other cables attached under it.
Can you modify the maintainer cable with a properly sized ring terminal? If not, can you stack the maintainer cable under the other ring terminals?
