Bad steering
PA
2010 Ram 2500. Noticed the steering was getting a bit....chunky. Like chunks of dirt going through a hose feeling on the steering wheel. Thought it might be the steering stabilizer on the front solid axle going bad. Checked the fluid level and it was fine and clear looking. A week later I checked it again and the cap to the fluid res. was gone. I know I tightened it. Could it have blown off from pressure? Could the pump be bad? It has a steering box that was replaced due to leaking a few yrs ago. Any thoughts?
Rochester, NY
I have this problem in my Volvo, I'm almost certain that it's the U joint between the upper and lower steering columns. I can feel it sort of bind as I turn the wheel. When I get the motivation, I'm going to remove the boot and soak with penetrating oil to see it that helps.
PA
Originally Posted by CT8
Have you looked for oil?
Yes. There is some around the fluid res. from sloshing when the cap blew off is all. All hoses etc are clean.
