I bought a quart last year at Tractor Supply for about $5.25. Every where else they wanted ~$20/qt. I have a slightly leaky auger gear box and it's way easier just to add the 00 grease than take it apart and reseal it. I got a inexpensive oil squirt can and it works just fine. My gear box is a cheap aluminum one on a Troy-Bilt snow blower. It holds very little grease.Thanks for the replies.. I'll check this weekend at the nearby tractor supply.
I don't have a drain plug.. Was going to try and suction it out.. Not sure if the housing is aluminum or a diecast. I inherited the machine from my pops he never did detailed maintenance just oil changes.. Machine runs strong 20 years later but wanting to give it TLCI bought a quart last year at Tractor Supply for about $5.25. Every where else they wanted ~$20/qt. I have a slightly leaky auger gear box and it's way easier just to add the 00 grease than take it apart and reseal it. I got a inexpensive oil squirt can and it works just fine. My gear box is a cheap aluminum one on a Troy-Bilt snow blower. It holds very little grease.
Whimsey
Pay attention that gear oil is not GL5 (or that is yellow metal safe) ....since auger is usually made out of bronze...and plain bearings in that housing too...take a #2 lith grease and mix 50/50 with some 90 wt gear oil maybe close enough
I'll stick to the recommended 00 lubricant.. I take it that the auger drive assembly is similar to a steering gearboxPay attention that gear oil is not GL5 (or that is yellow metal safe) ....since auger is usually made out of bronze...and plain bearings in that housing too...
