Hello all,
car in question is a 2002 Subaru outback with manual transmission. Owners manual states transmission / Front differential gear oil needs API Classification GL-5.
Looking for some advice/input. Had a transmission fluid change on June 30th. Was heading to a friends place today (July 4th) and while driving on the interstate suddenly it popped out of gear, thought it was odd but put it back in gear and continued. About 30 sec later it popped out again. I made it to an exit and checked the transmission level and nothing present on the dipstick. I made it to a gas station (checked 3 actually) but none had any manual transmission fluid, only Automatic. Given my options I decided ATF was better than nothing so I topped it off with that. took about 2.5 quarts. I had about 45 min drive home on the interstate. I'm planning on going back to the place I had to the fluid change and have a talk with them.
My main question is, since I used ATF, is there any possible damage I could have done? As well as any additional tasks needed besides draining the ATF and refilling of manual transmission?
Thank you all for your time.
-Rick
-Rick
