So I just bought an 02 Ranger with the 3.0L Vulcan and it has 66k original miles on it. It has been well taken care for the most part of its 17 years.
The trans fluid dip stick has a slightly brown, but non burnt smelling fluid on it. My question is, at 66k original miles, would I be doing more harm than good changing the fluid at this point? I don't know if the trans has ever been flushed or drained and if it hasn't been then it at least has 17 year old original fluid in it.
The trans shifts smooth as butter right now and I don't want to run the risk of possibly compromising it by washing the sediment out of the clutch packs with new fluid detergents and causing problems.
I understand that to some degree, this is always a gamble. I did a drain and fill on an older Buick with 195k miles on the original trans and it ran just fine for the two years after until I sold it. I have also heard of folks who have done the same thing on vehicles with significantly less miles and within a month had a useless trans. I want to take this truck WELL into the 200k mile range and I know that leaving the current fluid as is may or may not get me even close to that. However, a drain and fill with filter may or may not kill or extend the trans.
What say you fellow bitogers?
