anything bad about CITGO or harvest king?
canada
im looking to get some dexron iii for my truck and have the choice between citgo, harvest king, or valvoline. all 3 have dexron 3 licensing on the back and are dex/merc fluids. does it make a diff which i get? i assume all dex fluid is very similar but i just wanna hear if anything wrong with going with the harvest king. its dirt cheap. thx i can get harvest king for $30 for 7.5L motomaster/citgo is $90 for 20L valvoline is prob $40-50/ 5-6L thx
SW Ohio
If they are all truly licensed like you say, get the one that's readily available and/or lowest price. Licensing means the automaker that controls that spec says the fluid is 100% acceptable.
AR
There are VOAs here on the Harvest King oils, and they look fine. If it's appropriately rated - it should be good to go.
Ohio
If it is licensed and meets the specifications of the manufacturer, the least expensive is the way to go. Anything else is merely a wallet flush.
Cincinnati, OH, USA
Pretty sure there's no licensing left for Dex III, the licenses all expired at the end of 2011, GM licenses Dex VI as a replacement, so they'll all be "approved for use". I've had no issues with Citgo products, and WM is switching a lot of ST oils to Citgo, I would say their Dex/Merc is likely as good as anyone elses.
Upper Midwest
Correct, there is no such thing as a licensed DEXRON III product. DEXRON VI is the current license and this license supersedes DEXRON III.
apollo18
canada
Since there's no licensing what's does it mean when it says for dex/merc or suitable for dexron iii or something like this "For use in vehicles previously serviceable by DEXRON® III/MERCON® brands Suitable where Ford ESP-M2C138CJ or ESP-M2C166H is specified Meets Requirements for Allison C-4" Does that still mean it meets the dexron III specs and is good as any other one? Or does it just mean it's good enough and not actually confirmed by GM
SW Ohio
What if it had a Dexron III license when it was current ? It met the specs or requirements then, theoretically nothing should be different....
Cincinnati, OH, USA
Originally Posted by csandste
Wally World is switching from WPP to Citgo? Or Amalie to Citgo? Haven't heard that!
Some of the diesel oil has already made the switch, the ST 15W40 gallons now have a Citgo MSDS. https://www.msdsdigital.com/supertech%E2%84%A2-heavy-duty-engine-oil-sae-15w-40-msds
apollo18
canada
Upper Midwest
i heard that people say that all dex 3 is basically the same but is that only if they have the license? or is it good enough if the label says dexron on the front/back
Are you reading any of the posts in this thread (and the other one) or just making random responses?
Upper Midwest
Well of course it met the licensing requirements when it was manufactured.
apollo18
canada
i did read the responses im just confused on why it matters if the license expired. i assume all these were licensed back in the day and that means they were dex 3 certified and now even tho its expired they are still dex 3 certified. am i right? i dont get how the expiry has anything to do with it thats why im confused beacuse i dont want license expiry to mean that anyone can slap dexron or dex 3 on there product without actually being approved as dexron/tested as sufficient to be dexron
Upper Midwest
Yes some of that is correct, but it is expired because it has been superseded by a superior specification. Just so you know however that the blenders and bottlers do not put DEXRON III on the container as a licensed product, for example ExxonMobil states: "Mobil ATF D/M is recommended by ExxonMobil for use in applications requiring GM Dexron® III H" on their equivalent fluid. In every instance that this license is mentioned today it is always "in the opinion of" or "suitable for". None available today are "dex 3 certified" as you say. Even that ExxonMobil recommendation is a bit off, they say it is for those requirements but they also sell a DEXRON-VI fluid which is the correct recommendation per GM.
Virginia
Though I have read where certain transmissions have not always done very well with dexron IV... I think older Allison transmissions being one of them.... Sometimes it is just as well to run what originally came in there like Dexron III... My lady's Camry being specd Dexron III is what I am going to put in that 98 Camry transmission. Not Dexron IV.
GoVols
I agree Most consumers are not smarter than the factory engineers
apollo18
canada
thanks for all the replies, so it seems like the fluids i chose are not dexron certified since they certificate expired. so how do i tell the difference between two fluids if they both are suitable for dexron 3? obviously if they are both dexron 3 ceritified then i know it doesnt make a diff but since the certificate is long gone how do i tell which is better or which is closer to dex 3 specs thx
