I have done some reading on this stuff.
Any comments? I am confused on thier corporate literature however. They say that Evans is best used without a thermostat? Are they implying therefor and open-loop cooling system? Furthermore they claim that the engine will run much hotter without any predetonation concerns. The premise is that thier coolant operates in such way as to eliminate the "steam" spots in the engine block ramoant to conventional coolants. Royal Purples "Purple Ice" and Redline's "Water Wetter" products makes similar claims. I would assume a power loss on EFI engines as higher than designed temperatures would result in the ignition advance being retarded?
Thanks-
Thanks-
