Originally Posted by DGXR
I don't plan to use a HM oil until it is actually needed. My Corvette has 74,000 miles, same story.
Curious, do you run your oil to the point of failure (engine noise) or do you change it at some arbitrary number as a preventative measure? Or how about your coolant..do you forgo changing it until your temp gauge is pegged?
LOL I have no idea how you arrived at that place from my post. Your user name is perfect.
I stay on top of all maintenance. Oil changes for the Corvette are yearly or 7.5k miles, whichever comes first, using synthetic NON high-mileage oil. But I have never driven this car 7.5k miles in a year so the oil service is usually around 5-6k intervals. Here's a simpler context: This engine has no issues, makes no odd noises, and does not burn or leak any oil. So I will not use high mileage oil until there are aging symptoms and I have a reason to use a HM variety.
Coolant is changed every 4 years, plenty often enough considering the annual mileage. No issues there either, still has the original 24 year old water pump.
Originally Posted by jakewells
If it doesn't leak or burn oil i wouldn't bother i don't use it in mine.
Even simpler, thank you
Both are true. HM oils are perfectly safe to use in newer vehicles and you are fine not using HM oils unless symptoms creep up.
