What ever happened to good old fashioned water pump pliers for hose clamps?
I've always took off a lower hose vs a petcock, but I suppose you could do that too. Any chance the petcock could get rusted and opening it, it never closes again..Originally Posted by user52165
Originally Posted by slacktide_bitog
Once you open the radiator drain, you might as well do it all
If only it was that easy.
Been doing partial drains for years.
I think he meant to drain out whatever comes out of the radiator when you open the stopcock. For my Camry, it's about 1.25 gallons.
The petcock is usually plastic, so it shouldn't rust (unless it's a Mazda3 )
Every car though ?
Every car that I’ve seen within the last 20 years has a plastic pet cock (or nothing at all). It shouldn’t rust, however I have found that on totally neglected cooling systems some rust or scale that can get caught in the threads and o-ring of the pet cock...and it will feel kind of “crunchy” when you unscrew it. I’ve also dealt with some that just don’t want to come out and they snap right inside the radiator. And that’s ok as long as they aren’t leaking...not so good if they are because then you’ll need a new radiator, but that’s pretty rare. But for the most part these things are pretty simple to unscrew.Every car though ?
