any one ever test mobil 1 racing 4t 10w-40 motorcycle oil
AR
Shifts were nice in my Raptor 660R - but no analysis - cooling fan ran less, so ran cooler.
Jupiter, Florida
Originally Posted by BigRich954
looking for some test info ? is it just over price mobil car oil
There are both UOA and VOA results for that oil on this site. There are also tests on this oil from various manufacturers trying to compete. It's nothing like the automotive oil. With higher ZDDP, calcium and a generally robust additive package. It's also very shear resistant and has a high HTHS. A previous discussion: https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2976138
N.H, U.S.A.
Used it in the last decade ( or prior) to boost sump of poor performing ILSAC GF4 PCMO back in the API-SM days. Then ESSO changed the blend, cut back the PAO substantial and it isn't as outstanding as it was, so I dont use it anymore. No its not PCMO. EP/AW package has to be adjusted to accomodate wet clutch packs ad its not focused on Energy Conservation.
pa
heavier oils generally used in motorcycles need NOT meet the specs of 30 W or less, but there are a few small bikes calling for a 30 + if you use that it best be a motorcycle oil. when castrol + mobil differed in opinion + castrol was marketing group III fake synthetics before they were legally marketable as such they others followed using good but lesser group III's instead of real synthetic PAO + Ester oils forever screwing things up!!
Ca USA
It is likely given the numbers that our motorcycle oil is chiefly reformulated Auto oil... the degree of change reflects market share... either way M1 Auto or M1 4T oil will meet and exceed your mileage expectations... Here are virgin oil samples of $4.89 a quart Mobil 1 Auto Oil 10W40 and $9.98 a quart Mobil 4T Motorcycle specific oil... listed in parts per million are minor differences in the additive package you're paying for... [Linked Image]
Ca USA
Thanks to BITOG data I think we finding the single most common misunderstanding about motor oil is that higher zinc levels provide greater wear protection. fact is more zinc provides longer wear protection... but thats a moot point given the short oil change intervals owners favor... Zinc is used/sacrificed in very small quantities at time, so the total amount present in your oil does not change how much wear protection the oil provides, as long as you don't run out of zinc. "Lab Testing" and "Wear Testing" analysis proves/confirms that more zinc provides LONGER wear protection, NOT MORE wear protection. 1. Well known and respected Engineer and Tech Author David Vizard, whose own test data, largely based on real world engine dyno testing, has concluded that more zinc in motor oil can be damaging, more zinc does NOT provide today’s best wear protection, and that using zinc as the primary anti-wear component, is outdated technology. 2. The GM Oil Report titled, “Oil Myths from GM Techlink”, concluded that high levels of zinc are damaging and that more zinc does NOT provide more wear protection. 3. A motor oil research article written by Ed Hackett titled, “More than you ever wanted to know about Motor Oil”, concluded that more zinc does NOT provide more wear protection, it only provides longer wear protection. 4. This from the Brad Penn Oil Company: There is such a thing as too much ZDDP. ZDDP is surface aggressive, and too much can be a detriment. ZDDP fights for the surface, blocking other additive performance. Acids generated due to excessive ZDDP contact will “tie-up” detergents thus encouraging corrosive wear. ZDDP effectiveness plateaus, more does NOT translate into more protection. Only so much is utilized. We don’t need to saturate our oil with ZDDP.
Jupiter, Florida
BLS, I know what you are saying, and it's true in a generic sense. It seems 1200 ppm ZDDP has long been considered the proper level for old school engines and modest lifter loads. However, it's become clear after some recent testing that higher levels will carry higher lifter loads. So while Ed Hackett may be correct, we can still prove, via lab testing, that more ZDDP will carry a higher load before scuffing occurs. Some highly loaded lifters in hot rod engines have lifter failures at anything less than 2000 ppm. http://www.kirbanperformance.com/product_images/customer_support_item-_pdf-35.pdf https://tech.drivenracingoil.com/zinc-in-motor-oil/
Colorado, USA
It works very well, holds shift quality to 5000 miles in a high horsepower and torque shared sump inline 4-cylinder in my experience. Gets worked in the low and mid-range and roll on, and gets run up to over 10,000 RPM on occasion. Have you searched the motorcycle used oil analysis section? I posted a specific thread about M1 10w40 4T with my test results and it's clearly in the thread title, from December of 2018. https://www.bobistheoilguy.com/foru...1200-mobil-1-10w40-4t-racing#Post4865603 More recently I posted about M1 20W50 VTwin (shown specifically in the title) and you can compare that to the previous test which was the 4T. https://www.bobistheoilguy.com/foru...il-1-v-twin-20w50-5065-miles#Post5183041 Both of those oils have really good boron content as well as what I consider good zinc content for flat tappet engines with cam profiles that are more aggressive than what you find in an everyday automobile. BLS, again if zinc content is not relevant to the overall protection of an engine other than to extend an oil change interval, then there would be no addition of boron or moly or titanium, etc as anti-wear additives. Based on what is being said, the reduced zinc should be more than enough. Does anyone want to go there and say that should be the case? I believe it is understood excessive zinc can be a negative factor. However within a certain concentration range, there are benefits that some flat tappet engines can take advantage of, and it is a fact not speculation. The analysis posted in this thread comparing Mobil car oil to Amsoil oil... Mobil makes no car oil with that additive package and I think you said you do not know what era it came from based on posts in other threads. That test can't be considered recent or relevant when it comes to a Mobil oil comparison to any other oil, and certainly motorcycle oil that is available today for purchase and putting in a sump. It was posted recently when boron (in the context of motor oils and the most common form used) was mentioned as an anti-wear additive that replaces zinc, that boron is not an anti-wear additive but used as an antifreeze inhibitor (!). It is in antifreeze as an inhibitor to counter the effects of antifreeze on a cooling system, which is not "inhibiting" antifreeze in motor oil.
Upper Midwest
It has already been tested, it achieves JASO MA2 and JASO MA which are relevant motorcycle specifications. How would you test it to show it does anything better or worse than meet those specs?
nj
Thanks guys that a Amazing amount of info. I tried googling and searching and not much popped up so I wasn't sure if it was a new oil or garbage. I'm putting it into a single cylinder High worked quad that's known to Shear oils badly. I really wanted to use Rotella T6 which I normally use and everything
Colorado, USA
Hey no worries, I get excited and want to find something out so I post up sometimes myself. It is a bit of work to search, which I think the search function on this forum sucks, or even to go page by page through the threads. I came across a bit strong on that, my bad. Many times I will do a general Google search for what I'm looking for, such as name the oil I am looking for along with the words "analysis" or "used oil analysis" or "uoa", it pulls the threads in from this forum readily. For a 10w40, in my modded ZRX 1200, it held up really well. It did fall out of grade by just a little bit, however the 4T starts thin so it didn't lose much relative to where it started. Simply meeting the standards in terms of JASO as we know means nothing in terms of how well the oil resists shear. Where are you located? The M1 20w50 V Twin oil is stout in terms of sheer resistance as well. Could be fine if your climate allows for it.
Ca USA
What about no zinc oils??? As you know most aircraft piston engines are air-cooled, so they tend to run hot and due to this, they require the use of an ashless oil. That simply means that when the oil burns, it must burn completely and not leave any ash behind. Aircraft engines are mostly flat-tappet engines and they seem to get along just fine without any ZDDP...
Ca USA
You're welcome but don't fear the shear... Shear Stability is a measure of the amount of viscosity an oil may lose during operation. Oil experiences very high stresses in certain areas of the engine such as in the oil pump, cam shaft area , piston rings, and gears or any other areas where two mating surface areas squeeze the oil film out momentarily... but technically speaking as our oil shears down we don't see elevated wear rates because oil analysis shows as viscosity shears down the flow goes up and the concept of lubrication states the greater the flow the greater the protection...
Colorado, USA
It isn't all about wear rates in a motorcycle. Shear dramatically affects shift quality and can be a legitimate drivability and safety issue in a motorcycle. But hey, run that really thin oil in the heat of summer and miss a shift while you're moving through traffic or sit in stop-and-go traffic with the temperature needle climbing at idle with the oil as thin as water trying to provide pressure to the upper end and keep the lower end with sufficient boundary layer. No worries it's all in the name of faster flow, and lower wear rates, right? An engine can have oil in it that flows very fast but does a poor job creating a boundary layer. That does not reduce wear and tear. Motorcycles run very hot at times, and low speed oil pressure falls as viscosity falls. Viscosity must be maintained to a safe extent, therefore a thinner oil does not protect better just because it flows faster. I don't understand the logic you continue to share, BLS.
Ca USA
Mercy Bonz... understanding oil is why we continue to share BITOG data even if it challenges our beliefs... The Importance of Viscosity? Quote Blackstone Labs The viscosity, or thickness of the oil, is not nearly as important as many people think. Oil retains its nature no matter what thickness it is.Think about this: automakers are continually recommending lighter multi-grade oil in new engines. The reason is increased efficiency. It takes power to pump oil through an engine, and the lighter the oil, the less power required to pump it. The oil's ability to act like a solid and protect parts is not related to its thickness. If that doesn't sound quite right, consider this: The gears in a heavy duty Allison automatic transmission are doing the same work as the same machine equipped with an Eaton manual transmission. Due to the hydraulics of the automatic, it runs on a 10W automatic transmission oil.But the manual transmission uses a very thick (sometimes up to 90W)gear lube oil. The gears of both types of transmissions will have a similar life span. We don't find any significant differences in wear, regardless of oil thickness. Quote 540Rat VISCOSITY vs WEAR PROTECTION CAPABILITY COMPARISON: 20 wt oils rank between number 2 and 220 30 wt oils rank between number 1 and 233 40 wt oils rank between number 6 and 219 50 wt oils rank between number 39 and 228 60 wt oil, the only one tested, ranked number 101 70 wt oil, the only one tested, ranked number 177 So, as you can see, this is absolute PROOF that viscosity does NOT determine an oil's wear protection capability, even though many people mistakenly believe it does. As mentioned above, an oil's wear protection capability is determined by its base oil and its additive package "as a whole", with the primary emphasis on the additive package, which contains the critical extreme pressure anti-wear components. And the additive package has nothing to do with viscosity. In general, it is best to use the thinnest viscosity motor oil that will still maintain sufficient HOT oil pressure. Thinner oil is best because thinner oil flows, lubricates and cools critical engine components better than thicker oils can. Thinner oils reduce bearing temperatures and sump temperatures compared to thicker oils. Thinner oils can also help increase horsepower and miles per gallon. Using thicker oil than is needed, is going the wrong way.
Colorado, USA
The oil analysis comparison you show in threads you become a part of has nothing to do with what we are talking about, that oil is not made anymore by Mobil. The zinc philosophy is patently false, higher levels do provide better protection in some applications and you are saying that it doesn't. You are completely ignoring shift quality and oil that shears loses shift quality, and thinner oil does not provide the same shift quality in many motorcycle transmissions regardless if it's brand-new and thin or older and sheared down to the same weight. A shared sump motorcycle transmission is nothing like an automotive transmission, that info is irrelevant. Not sure what motorcycle you ride, but if you have a nice sunny day, go ride it and enjoy.
Western NY state
Current info from Mobil's websites lists lower ZDDP that shown here....
