That was my thought. I spend more time sanding/scraping the caliper brackets than on the pads. The pads are easy to clean up, quick swipe with a file and it's good enough--but the brackets, about ready to start just pulling them off, would be easier to get the clean.Just to add to the above comments on it, I think in theory, galvanized could have some benefit for us rust belters.
Problem is, this still doesn't address contact points around the pad ears, etc, getting sticky from crud build-up, pins getting sticky, etc. For me, that's what typically kills my brakes.
Every time I have to replace the front pads or rest shoes in my cars (especially my winter beater) the material is separating from the backing. Unfortunately I never kept track of what brand I put on long enough to know years later when they were falling apart. I've started buying higher quality pads and hopefully that will help. Corrosion is definitely a problem here.
Engineering explained recently made a video on YouTube showing different testing of pads sponsored by some company called NRS which let him use their testing facility to make the video. They did a salt spray corrosion test which I believe only the OEM and NRS pads passed.
Never thought about that, but you're right, on a new vehicle (or new calipers) I go a few years before this problem is there, then it just gets bad and stays bad. I know some mechanics will avoid using lube on the pad ears because of its attraction for dirt but I've added it for some level of corrosion resistance. It seems to work--if not driven that much, so that the lube is still there the next time I go to work on it.Doesn't take too long to clean but I've found the cleaner I get them the worse the rust returns. Don't have time to coat then area with paint and let it cure during a regular brake job though.
slow drivers tewnd to have loads of brake dust accumulating, and getting pads to stick more than I would like.I always do the ears, under the shim on the bracket, and on top of the shim. Caked on brake dust has never been a problem. It's nothing compared to the pressure applied to the brake pad and beats rust buildup. Just don't put so excessive an amount on that there's any risk of it getting onto the pad or rotor contact surfaces.
I put synthetic brake grease everywhere when doing a brake job. I was taught that in a brake class I took years ago. I mean, the amount and whereabouts of grease application was almost comical, but I’ve done it for years without issue. I put it on the caliper pins, back of the pads, on the caliper piston where it meets the pads, the pad ears, the caliper mounting bracket hardware (Under and on top), everywhere.
But it will still rust, and you know what? Never seen an issue because of the rust with brakes. It rusts, the brakes don’t seem to care.
