Another Boring Redline 5W30 Pseudo-SM VOA
SE VA, USA
Polaris Labs. Taken from my make-up bottle. Iron........0 Chromium....0 Nickel......0 Aluminum....1 Copper......1 Lead........0 Tin.........0 Cadmium.....0 Silver......0 Titanium....0 Vanadium....0 Silicon....15 Sodium.....18 Potassium..6 Molybdenum..810 Antimony....0 Mangnanese..0 Lithium.....0 Boron......20 Magnesium...14 Calcium.....2673 Barium......2 Phosphorous.1157 Zinc........1302 Water.......<0.1 Viscosity...10.5cSt TBN.........8.59 I don't know about the boron. They had re-run it because the Iron and Lead were high for a VOA. The first run Boron was only 8 and the Moly was 672. Also, the first run potassium was only 1. The first run TBN was 8.19, I didn't ask them to redo that. ΔB
Phila,PA
With how much the first test they preformed differs to this one. I would not hold any of those numbers to be totally accurate. Just compare Redline VOAs on the board to get a round about figure
SE VA, USA
It's a test of the lab as much as it is a test of the oil. I wanted to try something other than blackstone. These guys didn't have any redline in their database. They created a new entry for it. dB
ON, Canada
California
Originally Posted By: martinq
Originally Posted By: sammy
You got mad search skills, thank you
Cheers Sammy! Hope it helps.
Man did it ever, that looks like great oil. Only one virgin TBN of 8ish was about the only red flag I saw in any of them. I know when I changed to redline the first time it was like unlocking the hounds, my Hemi purred. And I am a fan of esters above all else based on my limited research. I will indeed do a UAO to add to the knowledge base when I get enough miles on my current oil change. it should be interesting because I have mostly short city trips and very low miles. It will take a year and a half for me to get 8000 miles on the oil change. Looks like my oil choice is solid, nuff said. Thanks again bud
SE VA, USA
repost because can't edit [Linked Image from newcelica.org]
Originally Posted by deltaB
Polaris Labs. Taken from my make-up bottle. [img]broke link[/img] Iron........0 Chromium....0 Nickel......0 Aluminum....1 Copper......1 Lead........0 Tin.........0 Cadmium.....0 Silver......0 Titanium....0 Vanadium....0 Silicon....15 Sodium.....18 Potassium..6 Molybdenum..810 Antimony....0 Mangnanese..0 Lithium.....0 Boron......20 Magnesium...14 Calcium.....2673 Barium......2 Phosphorous.1157 Zinc........1302 Water.......<0.1 Viscosity...10.5cSt TBN.........8.59 I don't know about the boron. They had re-run it because the Iron and Lead were high for a VOA. The first run Boron was only 8 and the Moly was 672. Also, the first run potassium was only 1. The first run TBN was 8.19, I didn't ask them to redo that. ΔB
